Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Engine and Powertrain
- How to Replace Thermostat
Step by step instructions for do-it-yourselfers.
Change a thermostat... w/out draining coolant????
Can someone give me some instructions on installing a new thermostat?? I would like to do it without draining the coolant if at all possible , since I just did a coolant change 2 months ago. Can it be done? Anybody have any good pointers?
Thanks guys
Rob
Thanks guys
Rob
Thanks guys
Rob
Thanks guys
Rob
Just drain it into a bucket and put it back in when you are done.
Of course you could stand the car on it's tail, then you would not have to drain and refill.
Convex tail on the C5 might make it a little tipsy, but should work better with the concave tail on the C6.
Received 3,812 Likes
St. Jude Donor '03-'04
Originally Posted by Dan_the_C5_Man
Just wait until "Evil Twin" chimes in!
And Chris , Im ashamed of you...
I change my stat twice a year... I never change or drain the coolant... I lose less than a pint of coolant...
here goes..:
ready??????
have the new stat ready with some silicone grease to hold the O ring in place... I usualy put the housing on the battery...
also have some anti sieze thread compound handy.. also on top of the battery..
with a cold engine/// (the old stat will be closed...///
put a catch can under the car ....to catch the 1/2 pint or so.. spo the neigbors dog doesnt die..
slide the clamp up the radiator hose...
then pull the hose off the housing and tuck it under the heater hose holding it high and dry...
at this point you have lost no coolant because the stat in the hosing is closed... and the coolant is cold..
now remove one housing bolt... the housing will still be tight to the motor.. apply alittle anti sieze to this bolt..
here comes the trick...
Now with some applied pressure to the housing toward the engine block.. remove the other bolt pressing firmly on the housing...
place this bolt next to the one you already put anti seize on...
grab the new hosuing.. and with one smooth motion... remove the old state and place th new stat on...you will losse 1/2 to 1 pint of coolant.. you can hold the housing to the motor stopping any coolant loss... now with applied pressure put in the bolt with the anti seize... ... snug it up , and this bolt will hold the housing inplace the coolant is not under any pressure...
now put anti seize on the other bolt .. put it in.. torque to spec...
pull the radiaotr hose from under the heater hose and slide on the housing... slide down the clamp... and you almost done... fill the coolant tank... with 50/50 dexcool... should be less than a pint.. start engine and bring to temp...once above the stat temp/// shut it down... let it sit a while... 15 minutes or so.. refill the coolant tank.. and restart... check for leaks.. run it up to temp .. then shuit down and your done...
The actual stat transfere proceedure takes less than five minutes.. the passage of one stat for another should take less than 3 seconds.... and at this time you will lose alittle coolant.. the only other coolant you will lose it when you pull the radiator hose off..that about 4 oz. the coolant infront of the stat to the crease you put in the radiator hose when you tuck it under the heater hose...
I do this twice a year...without a problem... 160 stat from may until october... stock stat from october to may...
I lost more than a quart, but then again its hard to measure when its all over the floor.
Some will drain out, but if you have a gallon on stand-by, don't bother to drain it. It will stop coming out after about 20 seconds, at least mine did.
Good luck, its not that bad....
I just did it this weekend.
I put two dish washing pans under the car next to each other.
I pulled the hose off first and then the T-Stat. Most of the old coolent went into the pans some did go on the floor but not much. Lost about a gallon.
this is a tried a true procedure
Holy Resurrection Batman!!
