fuel lines
fuel lines
i am replacing the fuel lines on my 69 and was wondering what you guys would recommend. i am thinking about going with aluminum tubing but i'm not sure. thanks
Originally Posted by Twin_Turbo
I'd go with stainless. Aluminium has a low tolerance to vibration.
Any problems with using all 3/8 Stainless to replace all of them?
Steve
edit for spelling
If your not looking for the luster of stainless aluminum will be fine.
Vibration will not harm it......airplanes are 99% aluminum.
Aluminum will not bend and flex like steel it will crack as steels will bend more.
Originally Posted by stpman
My 73 had a 3/8 fuel line, 5/16 return and 5/16 to the vapour canister.
Steve
edit for spelling
Steve
edit for spelling
He stated a 3/8 line would flow nowhere near my needs given 600HP requirements and said that even my old 427 was no good with 3/8 lines. I asked what I should do about the return line, he was noncommittal so I will leave it stock size for now as I am too lazy to swap it out as well. I was surprised, I have a good fuel pump as well.
Good luck
-Andre
