Dash wireing harness question
I put my steering column in but i dont know if my wireing harness is on the correct side of the column. I thought i had it right when i put the column in but i may be wrong. Can someone post a picture of what it is suposed to look like. Thanks
James
James
Received 1,468 Likes
Cruise-In II Veteran
Main dash harness should connect to the engine and forward lamp harnesses at the firewall on the left of the steering column. Dash harness then routes up and over the column along the back of the dash pad and beneath the speedo and tacho. Illustrations in the assembly instruction manual are helpful for approximate locations, but not great for actual routing.
