help with belts and pulleys
i just pulled the smog pump of my 69 and now i don't know what belt setup to use. the only adjustment i have is on the alternator. i have power steering, no a/c. can i use one belt? any suggestions?
thanks
thanks
Received 1,468 Likes
Cruise-In II Veteran
Consider purchasing an assembly manual. I can't give a nod to the '69, but the AIM for my '68 lists all the possible engine/accessory combinations and diagrams the belt routings for each.
Sorry I don't know the specific belt (have used the same belt since I bought the car :blush: ) , just remove the water pump pulley and slide the belt on it just before putting it back on, it is a snug fit.
Usually the race cars that run one belt on the crank & WP, the WP mounting holes allow some adjustment to tighten the belt.
Since your WP isn't adjustable, you need to figure out a way to route the belt around something that is adjustable, like the ALT or PS pump.
