Which HEI distributor
I am building an engine for my 76 coupe.
Which HEI distributors plug into my existing distributor wiring?
I was leaning towards Mallory. What are you guys using?
Thanks
JZ
Thanks
JZ
Received 1,468 Likes
Cruise-In II Veteran
What's wrong with the original GM unit? It's reliable and plugs right up!
That would be great but I sold the complete motor and started fresh with a 4 bolt main high nickel block. Everything is new.
So, do the Mallory's or Accel's wire up to the tach and stuff?
If not is it easy to wire up ???
I just put in the MSD. A no brainer. Very easy to adjust the max advance and the spring rate for bringing the advance in. The unit did not have an adjustable vacuum advance, which I understand that either the cheaper Mallory or Accel unit has.
