68-69 fender louvers question
Old 07-20-2004, 12:18 PM
CGGorman
CGGorman's Avatar
Default 68-69 fender louvers question
I can't seem to find this in any of my reference material...
The rear-most louver (both DS & PS) of my 68 are blocked off from inside. The other three are open to the engine. Is this normal? If so, should the blocking plate (or whatever) be painted body color or black? If not normal, why would this have been done?
Old 07-20-2004, 12:24 PM
stingray72
stingray72's Avatar
Thats the way they were made, and I do believe they were painted black from the factory.
George
Old 07-20-2004, 12:25 PM
corvtt1969
corvtt1969's Avatar
mines like that too, on the driverside only tho,(i think) and its painted body color. i always wondered if it was there so people couldnt reach into the cabin??? just my wild guess. - bob
Old 07-20-2004, 12:30 PM
68raggtop
68raggtop's Avatar
Mine is also blocked off and body color. I would guess that it has to do with the vent door being in that same area?
Old 07-20-2004, 12:55 PM
Easy Mike
Support Corvetteforum!
Easy Mike's Avatar
Received 1,468 Likes on 1,247 Posts
Cruise-In II Veteran
Yup. Blocked on each side. I've seen printed material which said the fakes were supposed to have been painted black at St. Louis to give the impression of being open like the other three, but every one I ever saw was painted body color.
Old 07-20-2004, 01:06 PM
sb69coupe
sb69coupe's Avatar
Default blocked and blacked
The rearmost louver vent on each fender was blocked off, and was blacked out at the factory after the body was painted. The factory used a semi-gloss black paint except on cars that were actually painted black, where the louver was left in body color.
Old 07-20-2004, 01:19 PM
Karfever
Karfever's Avatar
Old 07-20-2004, 01:20 PM
Corey_68
Corey_68's Avatar
Perfectly normal.
Old 07-20-2004, 01:53 PM
CGGorman
CGGorman's Avatar
I was planning on blacking mine out regardless, but it's nice to know that I'm doing the "right" thing.
THANKS!!
Old 07-20-2004, 02:07 PM
Garys '68
Garys '68's Avatar
rear blocked off on my 68 to. I always thought the others were there for access to the body/frame mount bolts. No need for the rear one for that access.
To 68-69 fender louvers question
Quick Reply: 68-69 fender louvers question
