Instrument panel dimmer switch replacement
Hello fellow vetteheads, has anyone had the opportunity to replace the headlight/instrument panel dimmer switch lately? The headlights pop up and work OK but the dimmer portion will not control the cluster lights very hard to drive at night with a flashlight LOL. I would appreciate some advice on the matter, have to fix it regardless just would like to know the degree of difficulty. Thank All in Advance. :flag
It can be done by removing the top dash cap, and maybe the drivers dash pad door jamb screws (2) The dimmer is part of the headlight switch so ya have to replace the whole thing. Not hard...just time consuming.
Eddie
Eddie
You didn't say what year, but we just did this on my friend's 73 for the same situation. Pull the screws on the front of the driver's instrument cluster, pull it forward as far as you can and then have someone with a small hand wiggle it up under the dash to remove the headlight pull ****. Pull your duct work loose from under the dash to give more room.
You will want to practice the removal of the **** on your replacement switch so you can do it by feel. This is very easy but you WILL scrape and cut your hand a bit.
Gary
Gary
Cruise-In VIII Veteran
Gary
Gary
Received 1,469 Likes
Cruise-In II Veteran
Go slow. There are two vacuum lines on that light switch in addition to the wiring harness connector. Trust me, you'll make your life easier and pick up a couple of inches of working space if you will lower the steering column.
I changed the one on my '77 recently. It was easier with the steering wheel removed. I did not remove the top dash board, but could access the speaker wires -- installed Kenwood speakers in the kick panels. I believe the spring loaded "button" does make it easier to remove the ****. I didn't know about the button until the new part arrived -- d'oh! One watch-out I can offer is to make sure the sheet metal nut tabs stay in place when re-installing the front driver's dash. Old ones fall out easy and might not be noticed until you realize the screw won't tighten.
I've heard that the vacuum hoses need to be in the correct location to work on the switch.
