Muncie case to bellhousing?
Old 07-18-2004, 10:55 AM
Jughead
Senior Member since 1492
Support Corvetteforum!
Jughead's Avatar
Location: Just because I'm paranoid doesn't mean people aren't out to get me...
St. Jude Donor '09
Default Muncie case to bellhousing?
Looking for the torque spec for the Muncie to bellhousing bolts?? They seem to tighten up and then stop. Don't want to crack the case or housing.
Old 07-18-2004, 11:39 AM
MotorHead
MotorHead's Avatar
Location: Who says "Nothing is impossible" ? I've been doing nothing for years.
55 ft/lbs
Old 07-18-2004, 12:15 PM
Eddie 70
Eddie 70's Avatar
Ci 6, 8 & 10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15
Did you chase the threads with a tap to make sure they were cleaned out? Or the bolts may be too long. Just a questioning attitude. One of those things they try to instill in us at work.
Old 07-18-2004, 03:47 PM
Jughead
Jughead's Avatar
St. Jude Donor '09
MotorheadWow, 55! Didn't think it's be that high.
Eddie----the bolt threads are all clear. It just felt funny when I was tightening and all of a sudden a stop. I'm a little spooked since I already cracked one bellhousing.
Old 07-18-2004, 04:04 PM
comp
comp's Avatar
can they be bottoming out???
Old 07-18-2004, 04:07 PM
Jughead
Jughead's Avatar
St. Jude Donor '09
Don't think so, the bolt holes are open ended. Probably just me.
Old 07-18-2004, 04:09 PM
comp
comp's Avatar
i can relate
Old 07-18-2004, 04:50 PM
MotorHead
MotorHead's Avatar
I could not find the actual numbers for the 4 speed Muncie for what they call "Case to clutch housing bolts" all other manual transmissions are there though even the 3 speed Muncie and the torque for all seems to be 55 ft/lbs
Old 07-18-2004, 07:47 PM
71coupe
71coupe's Avatar
Before you installed the pilot brg, did you make sure it slides freely on the end of the trans shaft? I've had one that was very snug that did not allow the trans to spin freely
Old 07-18-2004, 08:23 PM
Jughead
Jughead's Avatar
St. Jude Donor '09
To Muncie case to bellhousing?
Quick Reply: Muncie case to bellhousing?
