Torque spec for bellhousing?
Senior Member since 1492
Can't seem to find the torque specs for the bellhousing to block bolts? Can't be much since the bellhousing is aluminum.
30 ft/lbs, since I always take the motor out without the tranny I can't torque these properly because there is no room for the wrench. I just tighten till it's tight probably much more than 30 ft/lbs come to think of it and never had a problem.
