Harmonic balancer not going on all the way
Yesterday after installing the cam and and timing gears and chain, we tried to put on the harmonic balancer, it went on almost all the way but once it went in to certain point it just wouldnt go on anymore, you could see about a 1/4 inch of the shiny part thats supposed to go unto the crank, also the pulleys dont line up by about the same amount, im trying to put on the stock balancer. Could this be because i got a double roller timing gear, and thats its possibly thickers than the stock timing gear, and thus when the harmonic balancer pusshes up against it, it doesnt go as far in as it used to??? Any suggestions or advice? Should we just try to apply more force?
Your crank gear is probably not on far enough, how did you get it on ?
Push the cam gear into the block as far as possible rotate the motor a little and see how far the cam comes out, it should not come out very much.
Also how are you putting the harmonic balancer on, with the correct tool?
How could the gear not be fully on when the timing chain lines up perfectly from the top gear to the bottom gear? I did use all the proper tools to install the crank gear and the harmonic balancer. Im thinking of just trying it again and try to apply more pressure.............
Originally Posted by comp
hanging up on key ?????
Good luck. cardo0
