Need tuning help!
Need tuning help!
I got the engine back in the car, but am expiernciing some problems. When i turn the key, the engine rotates, but will not fire. There is not fuel from the fuel pump to the Carb, and none of the lines are pinched or anything. Is there maybe a Pressure problem? Also, after i turn the key off, with the starter still running, i remove the key and the starter still turns. I have to disconnect the negative terminal to kill the starter. Any opinions on that as well? thanks all!
