Camshaft break in lube
Most cam manufacturers sell break-in lube. I used it and also primed the oil pump with an electric drill through the distributor hole before even thinking about starting my engine. Follow your cam manufacturer's break-in instructions for running the engine during the first few to few hundred miles. I have seen camshaft lobes severly worn from improper break-ins.
At every oil change I prefill the oil filter so that it is ready to go when the engine is started.
Good luck with the installation.
