TH200R4 Transmission mount question..
I'm planning on installing a TH200R4 with my new setup... I wonder if the TH200R4 uses the same transmission mount as the TH400???
Does anyone know what transmission mounts I'll need and where to get them.. I'm looking to get poly mounts...
Originally Posted by comp
i thought a stock mount worked ????? I'm working on this trans. and a
383 for my truck
383 for my truck
I don't know.... I've never installed a TH200R4.. so I don't know if the standard tranny mount would work...
Originally Posted by mrvette
A parts house can set you up fine, just get one for a 200 equipped Monte or such,
GENE
GENE
Cool Oliver!
Looks like there will be 2 C3's sporting 2004r's at the challenge. Yours will be just a tad faster. But I might have an advantage of not having to worry about traction. That helps with consistency.
Hmm, now that the C5 is gone, will you bring the 68 to Bradenton?
Originally Posted by isosceles
Cool Oliver!
I'll bring the C3 to Bradenton as soon as the conversion is finished...
BTW - traction won't be an issue for me... Got my new ET Street slicks
(BTW - the tire on the right in the first pic is my old tire size )
Yes, you can use the th400 mount. I just took the trans mount and the shift linlage off of my TH400 and transferred to the 200R-4 and put it in the car. Hershey
Well - I have a Tremec TKO 5-speed in the car right now.. I can't use the tranny mount from the TKO.. but I can just get a regular TH400 transmission mount and it'll work!!
Originally Posted by AGVI
Why do people call you Oliver? Isn't your name Olivier or something?
Mungiecakes!!!
Mungiecakes!!!
Well - my real name is Olivier.. but I prefer to be called Oliver...
