tacho and headlight question
Hi, I had my dash in bits this morning and all the gauges out. The tacho wasn't working before I pulled it out and it's still doing the same thing.
The needle sits well below the zero point with the ignition off. When the ignition is turned on, the needle drops sharply a bit further. It's only if I rev the engine up quite a bit that the needle will flicker up a bit.
When I had it out, I noticed some dicolouration on the circuit board, does it sound like something on it has burned out?
2nd question.... When I bought my car, the headlights had been left up as the prvious owner hadn't been able to work out what was wrong with them. I discovered that the headlamp relays each had the centre tube broken off. I managed to repair the both of them and fit everything back today. I pulled out the original hoses as they were all buggered, and put in new stuff. I didn't think of hose lengths at the time....
The headlights work, but when I turn them on, nothing happens for maybe 5 to 10 seconds and then the drivers light slowly raises. About 15 seconds after that, the passenger light slowly raises. They close at the same time though....
Anyway, is it the hose length differences causing the delay between the light the drivers and passengers light popping up? I assume I have a vacuum leak somewhere that would be causing them to wait so long before they come up, but what is the most likely offender?
In addition to all the hoses, I'd check the line from the engine to the vacuum cannister and the cannister itself. Then there are the actuators. If the lights are going up and down, the main diaphragm in each one is probably OK, but look at the seals on the shafts. After time, these can develop small cracks which are leaks. I replaced some of them on mine and the lights work much better.
Originally Posted by Z-man
Maybe it happened when someone cut all those wires out and laid them on the sidewalk!!!
I replaced all the hoses for the lights, but after reading around this forum and the net, I've realised that I don't have the filter or check valve that go on the back of the intake manifold. Dunno whether the filter is such a drama, but I assume that the check valve was originally installed for a reason...
You'll pardon my innocence, but I actually thought the lights were supposed to come up at the same time..... :blush: :bb makes sense with your weaker/stronger spring theory though
Sounds to me like you might have a bit of a vacuum leak somewhere. Check the vacuum tank in the fender, they are notorious for developing pinholes in the bottom. Either that, or a large cam. That would explain the slow opening. I do remember with the extremely large Crower cam that used to be in my car, I would actually have to get out and give the lights a little pull or they wouldn't come up.
Location: Kansas City, MO ...I'd like to go fishing and catch a fishstick. That'd be convenient. - Mitch Hedberg
Sounds like your tach circuit board might be bad. Mine read twice the actual rpm before I replaced it. It's a simple part to replace.
Ecklers must love me by now...
