when do you shift
when do you shift
Every since I started racing Spec Miata's I have figured out that I am a shifting weeny in my street car. I normally shift at about 2000-2500 rpms in my 68 with a 327/300 motor. When do most of you guys shift. I would assume somewhere closer to the yellow then that. Thanks.
normal driving around 3500...getting on it I usually stay just below 5k...the difference is usually in how far to the floor the gas pedel is, not where I am shifting...
Mayberg, there's my problem, I have never used the R before. I always wondered why I had a garage door that opended on one side and just a big hole on the other side.
