Who here can lock up their brakes?
Just curious
I've heard other people say they can't no matter how much work they do on them. Seems to me that I should be able to though. I just got through making my custom booster pushrod extension, reinstalling the booster, bench bleeding the MC, reinstalling the MC, and bleeding all 4 corners (yes in the right order).
And now my pedal is hard as hell. I don't get that lovely 5" of travel before getting any resistance anymore thanks to my pushrod extension. But I never have and still can't lock the wheels up no matter how hard I push. I know my booster is good. It's not that. I can get the wheels to just squeal/howl slighty, but they won't lock up. Is this normal?
I have hydraboost and if is easy to lock all 4 corners, even at 80 mph you can make all 4 wheels squeal without pushing too hard. Did it my accident a few weeks ago.
The vacuum booster can not begin to compare with the power of a hydraboost.
Norval, I didn't know you had an accident! Were you hurt? How is the car?
I did a search and didn't find anything, so link me to the post , if there is one, so you don't have to go over it all again.
I don't have any problem locking up the brakes. My system is stock with the following changes:
Braided hoses.
Raybestos brute stop pads
High-perf synthetic fluid (DOT3/4).
Springs removed from rear calipers.
Using a new (not rebuilt) booster and MC. I had all sorts of problems with rebuilt boosters. I could NOT lock the wheels with any of the 3 rebuilds I tried. On 2 of them the pedal would slowly go to the floor (dunno how a bad booster can cause that, but it did). The 3rd one had no assist at all. Paid the $200 for a new booster from GM and problem gone.
Braided hoses.
Yeah, I read on the Hydraboost website where they describe the stock boost system as being "inadequate" to take advantage of the C3s big azzed rotors and calipers. I can certainly attest to that! I'm just wondering ...
1. Am I performing as well as be expected with a stock setup?
2. Has anyone made any modifications to extract more braking power out of the vacuum brake system?
NO ACCIDENT. SORRY
Locking up
Your tire diameter and how sticky your tires are has a big effect. Pad type has some effect as to the temp range where they work the best.
Hydra boost is the real way to go.
From day one with my 79 I have been able to lock tires. Now in the sub 70 mph range a Norval stomp panic stop will send out big clouds of smoke off my rear tires and big long black marks 315 in width. with smaller diameter fronts they lock.
I use synthetic dot 4, all new HD stainless steel O-ringed calipers, with PF pads from autoZone.
St. Jude Donor '07
I can now
In theory, yes, loss of vacuum should still allow you to push on the pedal to stop the car, but you'd probably be standing on it. But, mine was acting funny. It seems like whatever mechanical linkage backup is in the booster wasn't working, it's like the booster wasn't pushing on the piston in the mc hard enough. I don't know how to explain it, maybe some else can?
Originally Posted by wcsinx
You're the second person today I've heard say that. I'm befuddled. How can a bad booster cause you to lose pressure at the calipers? Shouldn't you be able to brake as well without vacuum assist by just putting more pressure on the pedal? The booster doesn't affect the operation of the MC?!?!
Re: Booster: I'm as baffled as you as to why the bad booster would let the pedal go to the floor. I thought the booster had a mechanical connection between in and out. But alas, sitting at a light with my foot on the pedal I could feel it slowly sink until it hit the floor. Even weirder was that the brakes felt normal during light braking. It definetely had assist until the halfway point.
All this time I thought it was a big-block thing. I drove a 79 and could lock the fronts on demand. But the '74/454 (that used to be pictured below - I'll get that working one day) slows just fine, but I don't seem to ever lock them up.
I rebuilt the brake system during the winter of 2002/2003 - sleeved calipers, springs removed, DOT 3/4 fluid, new organic pads, new front rotors. The brakes are great, but I'm not locking up.
And I'm assuming you replaced the booster independently of the MC?
I know it's hard to lock mine up; however, a couple of months ago some ahole was in the left lane to make a left turn and decided to go straight and cut into the right lane. I naturally hit the brakes and the screeching began. The next day I notice 30' of rubber marks. That my have been the only time I locked them up.
Mike
Mike
ZTI o ring pistons , hydroboost , braided lines , hawk pads = brakes as they should be on a vette ! And yes as Norval said lockup is no problem ,,,,,,,,,,,,
G
G
