Need pwr steering bracket pics
My pump on my 80 is not lining up with the crank pulleys. It has been awhile since I put the stock brackets on and am unsure if I have it right. I have one of hte slider bracket bolts throught the motor mount attachment bolt. Any pics would be appreciated.
I don't know what's on your year but here are the brackets that hold the pump on my '72.
Upper Bracket
Lower Bracket
Both
I don't know if this helps but I had my brackets handy sooo....
Craig
Upper Bracket
Lower Bracket
Both
Craig
Thaks Vettenut and Paul. Those look like mine. Now on the upper bracket, where there is only on bolt hole, does that bolt on to the block where the motor mount bolts?
Thanks.
Eric
Thanks.
Eric
Thanks.
Eric
Thanks.
Eric
Craig
