fuel line hitting cooling line
I installed an Edelbrock Performer carb on an existing Performer Intake. I bought an Edelbrock fuel line with filter (the one that installs pretty nicely on the carb. The problem is, where the fuel filter attaches to the line, it is right on top of the return heating/cooling line coming out of the manifold. The filter actually touches the hose. How can I get around this?
"Rodstoration &am p;quot; In Progres
I'm dealing with the same issue... I left it as is and am going to watch your post for any suggestions. Here's a Bump to keep it visible.
Aeroquip Hose
With my Holley carb, I used Aeroquip -6 hose and installed an inline fuel filter part way up the hose. At the fuel pump there is a 90-deg elbow that helps direct the hose. There is a special adapter that I purchased through Summit Racing to connect to the dual inlets on the carb.
I had a similiar problem with the inline filter I put on my Qjet. The line from the filter to carb was a hard line with a little piece of flexible to attach the filter. I just twisted the fitting to rotate the filter up higher and off the line. If all the lines are flexible. Just fabricate a bracket to hold the filter on or make a little shield that attaches to the filter and raises it off the line.
