Cutting springs
Cutting springs
Still unable to fix loud clanking noise problem inherent with my S.B. coil-over shocks but I really like the car's look at 26.5" front fender lip height. So after 4 months wasted trying I'm going back to stock. I have the original springs and wish to get 26.5" with 25" tires (245/60/15). Need to know;
1. what stock height was, I believe 27.5 - 27 3/4."
2. how many coils to cut off stock springs, I'm guessing 1 3/4 to 2 coils.
Let me know. thanks.
If you cut off 2 coils you will be buying new springs, start with 1/2 coil, you may have to do it twice but you won't have to do it twice and buy new springs, ask me how I know
Also drive it around for 2 or three days after cutting so they settle and you can see the settled height, roliing it back and forth doesn't do it.
27.5 - 26.5 = 2 in, ?
All Vettes are different and different springs will give you different heights
go ahead.
go ahead.
I am trying to save you some time and money, it is a trial and error sort of thing you can't really say 1 coil = 1 in. or something like that. If I were you I would start with 1/2 to 1 coil, no more than 1 coil. You can also get too low, it looks really cool but you are constantly worried about scraping going into parking lots oe any dips in the road, that's why mine is not so low any more.
See that's what sucks. With the coil-overs it doesn't matter much since you can adjust the collar the spring sits on and make up for either cutting too much or too little off to get the height you want. In theory my coil-overs are the best of both worlds but the noise is UNBEARIBLE!
Hello..My stock height was 28"..with 255/60/15...I cut 3/4 of 1 coil..and it droped it to 26 3/4.. I drove the car around and checked it again...its at 26 1/4..
Does anyone know the spring #rate of stock front springs? VB&P #460s might be a little harsh for my driving. I was thinking about stk springs w/1" cut. What would that #rate be? The other side is, VB&P knows what's up! Any thoughts? TIA
Rick
Rick
St. Jude Donor '09
If it's adjustibility you're after, why not go with a transverse glass spring?
Mine rides much better than the cut VB touring coils it replaced and I'm at 26 1/2" with room to play
Rick
Rick
Originally Posted by Redshark6974
Cali, did the coilovers go below 26.5"???
I think 3/4 turn is going to get you real close. I base that on very unscientific research which is when I cut 3/4 turn off a set of Z28 springs on a 75 Camaro I used to own and it lowered it 1.5". Yep, different springs, different car... as I said, unscientific.
Senior Member since 1492
3/4 coil.
David,
You must be getting really good at separating the ball joints from the spindle. I have the hardest time getting those things to let loose. When I read that shortening the springs was a trial and error process I thought OMG I would go insane. I usually have to replace the ball joint because I screw them up so bad getting them separated. What is the best way to get them to separate without damaging them?
David
David
