Starting Problems
Starting Problems
Its been wicked hot here in Denver and my 80 is getting harder to start. Sometimes I go out and it starts right up. More often though, it just makes one clicking noise when I turn the key, followed by nothing. I turn the key many times fast, repeating that clicking and every so often it turns the starter and it will start up. There is no grinding noise like a bad starter, and it is not a bad battery because I bought a new one, and it doesn't respond to a jump. A few weeks ago I discovered that my old battery was out of water, I thought that might be the problem but it wasn't. The battery connections are clean. Also, for the longest time now, when I start the car, my battery guage remains very low to the left until I rev up the engine. Revving it causes it to move (and stay) just to the right of the center. Has anyone lived through this problem? Are they related? What is the problem and what can I do? Thanks Tom
You might also check out the battery negative side ground to the frame. A poor ground can also produce your symptoms. Take out the ground bolt and clean the area before reinstalling. Also, check the engine ground strap. If it is your starter, take a small hammer and give it about 10 medium taps along the body. If it then starts, drive to your local parts store and buy a new one.
