Rubber Gaskets and RTV Sealant
Canadian Events Coordinator
Can I use RTV sealant with rubber valve cover gaskets?
I read it was a bad thing to do.
Aren't RTV sealants silicone based?
Won't they kill the rubber gasket?
Thanks, Les
Thanks, Les
Received 4,924 Likes
I run the rubber gaskets with no sealant, but it doesn't cause any materials compatibility problem to use the silicone. I've found that the rubber valve cover gaskets can succcessfully be used dry if your valve covers are not bent and proper torque is used.
The reason why RTV sealants aren't recommended for use with rubber gaskets is the tendancy for the gasket to "slide out" when the parts are bolted together due to the slipperyness (?) of the sealant before it sets up.
I use Permatex gasket maker (modestly) to hold the gasket in place on the cover side. I do find RTV and rubber is a slippery combo. BTW my former 1979 L-82 did not have gaskets, only RTV!! That was the factory recommendation.
I dont use RTV. Instead just use weather strip cement and glue the rubber gasket to the valve cover. Nothing else is nessesary, and you should be able to reuse the gasket a few times!
