How low is my car??
How low is my car??
My 70 has had to have lowered - from the Fender Nose to the ground is 20" and the back bumper to the ground it 21" - what is normal height and where exactly do I need to measuring from. I am getting new wheels etc. and was currious -
thanks
Mark
thanks
Mark
here are the measurements
They Measure 27 1/2 from ground - the drivers side is about 1/2 lower at 27 - what is the normal stock measure measurement -
thanks!
Mark
thanks!
Mark
Measure the real Z&D heights. These are suspension measurements, not body measurement. Measure the difference from the lower ball joint on the lower control arm to the center of the bolt on the inner side of the lower control arm. This height difference is the way they were measured when they were built.
thanks!
Mark
thanks!
Mark
I'm not sure what stock is but the 25-26 range you'll start to have clearance issues.
Senior Member since 1492
The AIM lists stock fender lip height at 27-28 inches, so you're right on there.
ddecart is correct also.
St. Jude Contributor
Your pic's pretty small, but from what I can tell, your ride hieght looks fairly normal. Believe it about the clearance issues--my front springs got a little soft over the years, and one day I took a sharp right turning into traffic and lost a 2" chunk of the lip of my fender well. Looked good sitting that low, though!
JB
JB
