T-10 side cover gasket
Anyone know where I can get just the gasket? It's leaking....and I figure I"ll replace the gasket after I pull the cover. Sure after 26 years the orginal gasket is not in the best shape.
I think you are only going to be able to get the side cover gasket in a set for a complete reseal. Might not be a bad idea anyway if the tranny is that old. If you just want to reseal the side cover why not go with RTV or another gasket maker. Maybe someone has already tried this and will chime in. Good luck.
Originally Posted by adam
Zip has the gasket set for about $9 - big spender. Or you can try the
goop as vettefixr suggests.
Do they take payments?
ty
