I need some EXPERT engine part help (rod bearings)
I recently pulled the oilpan on my 78 to put a new gasket on it and clean it in general, knock out the dents etc. Well I thought maybe while I was under there I'd check the rod bearings since I get a little rattle when I start it, just before the oil pressure comes up. It has good strong oil pressure at all times. 40psi plus running down the highway and 25 to 30 at idle. Just rattles a little when you start it. So, I pulled the #5 cap to see what was going on. Bearings show wear as suspected, but the journal looks real good. I am not in a position to rebuild at this time (lack of funds). So to prolong the life a little I thought I'd just pop a new set of bearings in. Here's where the problem comes in. I can't find any .0005 OS rod bearings ANYWHERE!! My buddy at GM ran the part# (off the bearing) and said they aren't available anymore. Machine shops say the same thing. I can't find any. Anyone have any ideas here?? I think I should have left this sleeping dog alone..... :blush:
Thanks
Thanks
you can run a standard bearing and should have no problems , as your crank has most likely lost that much metal over the years , but if you want to be very precise you can mix a std. bearing with a .001 os to acheive the same clearance. there is alot of more information about bearings that can be found on the internet i suggest doing some reading , as there are many choices .
Cruise-In I Veteran
Cruise-In II Veteran
just use the top half of a .001 OS bearing. these special size,.0005 OS bearing were only made for the factories. you can mix different size inserts to get the correct clearance
