Manual Brake Problems – Petal to the floor
Having problmes with a 71 with manual brakes...
I just pulled the rotors off of my ’71 to have them turned and put new brake pads on. After a through bleeding the still pedal goes half way to the floor and only then begins to firm.
After pumping the brakes there is fluid rushing back into the master cylinder under pressure. aka a mini fountain...
The front calipers are less than a year old and the rears are in good shape, seals too. I think the master cylinder is shot, because there are no leaks anywhere in the system. Does this sound right? I have been trying to chase a soft petal problem, so any further advice is welcome.
I also have been trying to find the correct bleeding order. The rear calipers have 2 bleeder screws, one toward the front and one toward the rear. Do I bleed both, and if so does it matter which one I bleed first?
First of all: Correct bleed order
Driver Rear Inner
Driver Rear Outer
Pass Rear Inner
Pass Rear Outer
Driver Front
Pass Front
Bleed them correctly first, and if you still have a problem then rebuild the MC. The parts are cheap, and it doesn't take long. (in fact, you might want to go ahead and do that now so you don't have to bleed twice) What you're describing kind of sounds like you're blowing past the first piston seal in the MC.
Driver Rear Inner
Driver Rear Outer
Pass Rear Inner
Pass Rear Outer
Driver Front
Pass Front
Also, there are two bleaders on each rear and one plug. The bleaders all face the front of the car and are up on the top, The plug is in the outer half and down low. You don't do anything with it.
Driver Rear Inner
Driver Rear Outer
Pass Rear Inner
Pass Rear Outer
Driver Front
Pass Front
Driver Rear Inner
Driver Rear Outer
Pass Rear Inner
Pass Rear Outer
Driver Front
Pass Front
Pass Rear Inner
Pass Rear Outer
Driver Rear Inner
Driver Rear Outer
Passenger Front
Driver Front
I thought you started the furthest from the master cylinder and worked forward (i.e. Passenger Rear)??
On most cars, yes. On C3s, no. That's just one of many quirks about these cars. I think it's something about the way the proportioning valve is setup?
