79 corvette electrical
Hi everyone.
I have a friend with a 79, that will not hold a charge. It has a new battery and we have had the alternator tested and have been told it is ok.
There are no warning lights on when driving. Could this be a voltage regulator issue? What else should I look for? Where is the voltage regulator anyway?
Thanks
Thanks
Originally Posted by rp23g7
Hi everyone.
Thanks
Thanks
Mine did the same thing.....ended up being a poor ground cable to the frame from the battery.
My 79 is doing almost the same thing. Even with a new battery, it will only hold a charge for a couple or three days. I gave up and installed a disconnect switch.
Mine used to do the same thing- it had a disconnect switch, but turned out it was a short in the factory alarm (drivers door)- the alarm no longer worked, but was draining battery all the time.
It took about 3-4 days to drain it (if I forgot to turn the kill switch)
~Kevin
~Kevin
Your best bet for electrical troubleshooting is to use a multimeter. Set it up to be an ammeter. Put it in series with your battery (engine off) and you will probably see a current draw. Pull your fuses one at a time. Record which fuses make the current reading drop significantly. That should point you in the right direction to start looking for shorts such as loose connections, wires that have worn through thier insulation and are rubbing against metal, corroded contacts, flakey switches, etc.
You want all your electrical connections to be tight, free of dirt and rust.
FYI your voltage regulator is inside the alternator.
These problems can be a real challenge to track down so good luck.
