Finally got her running.......PINGING!
Old 07-12-2004, 07:34 PM
noblejr
noblejr's Avatar
Default Finally got her running.......PINGING!
I finally got my engine back together this past week. I had removed the intake manifold to paint it, and I put a rebuilt water pump on, set the timing and everything. There is now a rhythmic pinging coming from the front of the engine. I don't think it's the fan, I've checked it's clearance about 4 times now, but it sounds like a fan blade tapping metal. There are 3 pings that reapeat themselves, PING..........PING ping............ It dosen't sound like it's coming from inside the engine but I may be wrong. I'm about to go cut up a hose and listen through it to try to pinpoint it. Does anybody have any insight into what this noise may be?
Old 07-12-2004, 08:48 PM
Ron 75 L48
Ron 75 L48's Avatar
I'm certainly no expert on this but it sounds like maybe the "rebuilt" water pump may have a bad impeller on it. Just a guess but at least this will give you a bump up to the top.
Ron
Old 07-12-2004, 08:51 PM
MotorHead
MotorHead's Avatar
Location: Who says "Nothing is impossible" ? I've been doing nothing for years.
Pulley is probably hitting the pump at some point usually near the top
Old 07-12-2004, 10:54 PM
noblejr
noblejr's Avatar
Well, I cut a piece of hose and as I held it up to my ear and begin to probe around for the source of the sound, it quits. I keep searching for a bit and as I finally give up and take the hose away form my ear, PING.....PING!. But it stopped pinging right after that and hasn't done it since. I now think it may have been the pully hitting the pump. Now that I think about it, I did re-tension my alternator belt at some point today. Maybe it was able to pull the pully off center just a hair. Thanks for your replies.
To Finally got her running.......PINGING!
Quick Reply: Finally got her running.......PINGING!
