Spark plug wires
Spark plug wires
Just bought a set of pre cut, triple silicone spark plug wires for the 82. Before I start pulling wires can I expect any surprises? Will I be able to get them all from under the hood or do I have to get some from underneath?
I plan on removing the wires one at a time and installing the new one before removing the next. Make sense?
I will be doing the same soon. I dont see a problem with getting to them from the top. The only problem I see is that some of the wires are run through heat shields and you might have to crawl under the car to snake them out of the shields. Good luck.
