Battery Going Dead ????
6th Gear
Ok, I am at a loss. My father-in-laws 1978 has a brand new battery that keeps going dead like over night. has anyone ever encountered similar problems ? what should i look for ?
how do i test ?
i knbow i am looking for a power drain/short. But where ?
Please help.
Thanks
how do i test ?
Please help.
Thanks
I would start by making sure the interior lights are shut off when you close the doors. Sounds simple but easy to check. In the past I have taken a fuse out of the fuse box one at a time until at least I've narrowed it down a bit. Get a volt meter to check the drain over a couple of hours. If the battery is new , probably won't be the battery. However, vettes are pretty hard on them and could break the plates inside of them. Disconnect the battery and see if it holds a charge over night.
Also check the archives here, there are some past topics on this problem.
Good luck.
Good luck.
how do i test ?
Please help.
Thanks
how do i test ?
Please help.
Thanks
Cigarette lighter hot wire insulation had worn thru and was shorting out There are so many possibilites--Milo has pretty good starting point.
SEMPER FI--1970 Dave
Meanwhile, you could install a battery cut-off ****.
