[Steeroids] My engine is baking the grease out of the U-joints!
My headers are baking the the grease out of the u-joints connecting the column to the rack. One of the joints is particularly close to the header, but there is absolutely nothing I can do about that. I'll post pictures tomorrow.
Has anyone else experienced this?
I'm probably going to order a lifetime supply of u-joints "just in case"
Originally Posted by comp
are you using a high-temp grease ?
That does bring up a good point though. I wonder if I can disassemble a u-joint and put high temp synthetic bearing grease in there. Maybe someone from speed direct can chime in.
Originally Posted by Steve Straus
The u-joints aren't serviceable, they're too small to have zirk fittings. I'm using whatever grease came in them, I don't know if it's high temp or not.
71 coupe, that's what I did for my spark plugs on this header set.....should work fine for the steering also....just a metal piece with a tab on it, clamped to the header pipe....with a stainless hose clamp....
GENE
GENE
GENE
GENE
it may need to be greased with a needle , i know there are greases that
take 500degs. i don't remember the name of the stuff iv'e worked with
that wasn't Valvoline or Moble 1
Premium Supporting Vendor
Steve, the u-joints can be disassembled but it is a pain to do it. It is similar to changing u-joints on a driveline. High temp grease is a good idea. I think a heat shield on the header tube is a really good idea as well. A small piece of aluminum and maybe some header wrap would do a lot for reducing the heat in that area.
