What throttle cable bracket should I get?
Well, I finally got the engine running well enough to where she will move on her own power, but the stock throttle cable bracket makes me nervous. It is only attached by one of the carb studs, which means it can rotate freely if the nut ever came loose. I have an Edelbrock carb with the stock throttle linkage. What throttle cable bracket do you guys recommend I get?
edelbrock makes a throttle cable linkage that bolts to the edlebrock carb itself, i've got one on my 71 el camino, works great. Try checking summit or jegs, they'll have one.
