So Long head unit; Hello touchscreen LCD
Since the new C6 came out with the in-dash LCD I started looking again for a similar unit for my 2000. Found this unit which is a option for those of us looking to replace our factory head units.
http://www.kenwoodusa.com/product/pr...productId=2557
St. Jude Donor '08-'09
That would be an awesome screen to have. I wonder if it fits as well as the one posted by the person who posted this thread?
pm or email me and i will tell you what software you need to run on that. I did something like this on my '97 Cobra. Lets see how long it takes for you to realize who this is
hint: www.mp3car.com (abcd-1)
St. Jude Donor '05
CI VI Veteran
Originally Posted by eRiCdWoNg
Awesome! Id love to do something like this. Hope you have dark tint and good alarm.
Nonetheless, very nice job.
Mark
very cool... i'm doing the same thing, about 75% done
you should drop winamp and run a better all in one front end... i'm using (going to use once my install is complete) centrafuse... check it out www.fluxmedia.com It's really slick and touchscreen friendly.... and it's free. Dave; the guy who wrote the software is really helpful and he's writing an obd-ii interface for that front end. Great part about it is that everything is 'skinnable' which will let you customize the interface and have it look how ever you want.
(if anyone is interested, here is a little write up about my project http://forums.corvetteforum.com/showthread.php?t=983973)
Hey ramcharger,
Did you use the 7" lilliput? I'm very curious, because the research I've done shows that the screen alone (without the housing) for a 7" is 4.25" high. The 1.5 DIN slot in the dash is 3.5".
Are my numbers wrong? I really want to do this, but I definitely don't want to hack my dash apart. My goal is to be able to return it to stock form if needed.
for those of you wanting simplicity and elegance, why not mount one of these?
www.oqo.com
'set up a dock' for this double-din sized unit, do it all - and stuff it into your pocket when starbucks' hot spot is juuuuuust out of reach .....
FreeStyler
www.oqo.com
FreeStyler
St. Jude Donor '03-'11
Originally Posted by m1k3
Hey ramcharger,
I went with the 7" initially, but then converted to the 8" after moving the HVAC unit down.
I plan on doing this install shortly. I have the center console radio surround on order, which I intend to modify. I will take step by step pictures.
I'm going to use the Kenwood P-NAV7015 system. I believe it's the same one that's in the C-6.
Originally Posted by 99C5Vert
Your calculations are not wrong... there's a little hacking involved.
Thanks for the info.... What kind of hacking was involved when you had the 7"? Do you have any pics of your setup?
www.oqo.com
FreeStyler
www.oqo.com
FreeStyler
red
