[slightlyOT] How hot is too hot?
(Not the 'Vette, but classic Chebbie - you guys are the best resource I know)
I just re-installed the A/C on my '70 396 El Camino and, not surprisingly, the car is running a bit hotter. Before A/C, it never got above 180. Now it climbs to 210 or 220, but only on the highway - around town it stays around 180-190. This is all with the stock temp gauge (which I know may not be accurate), but obviously the car is running 30-40 degrees hotter than before. I put in some Water Wetter, but couldn't tell a difference (still running 50/50 glycol, though). Is this too hot or not? If so, what do you think is causing it? Thanks!
St. Jude Donor '04 & '05
I find it strange that it's hotter on the highway than around town. Usually it would be the other way around due to the increased airflow when on the highway.
Have you checked your radiator hoses? I have seen cases where the bottom one will collapse at highway speed if it is soft or missing the internal spring. This of course would restrict flow and make the temp rise.
Also see:
http://forums.corvetteforum.com/showthread.php?t=859232
Good Luck!
Also see:
Good Luck!
Does your cooling system have an overflow bottle???? the older systems that didn't have bottles the coolant was about 4 inches low when cold.... It always helped my cars to add an overflow bottle!!!
But it sounds like your radiator is clogging-up
Water Wetter will only really help if you are running without antifreeze...
Have you tried to remove or relocate the front license plate to get more airflow at highway speeds??
I, too, was surprised that the temp went up on the highway, but not at lower speeds - I'm wondering if the problem (if it is a problem) is due to lean mixture or advanced timing.
I don't have an overflow, but definitely need one - this is my daily driver. Also, should definitely get a better gauge. Probably should reduce amount of glycol and try more Water Wetter.
I don't think removing the plate on this car would help any.
Remove the front license plate? Its an el camino, there's chrome bumper and the pull for the hood latch back there. I"ve got a 71 small block SS 350 with ac, just about the same setup and mine doesn't get that hot. You should have an overflow tank mounted near the passenger frame rail on the inner fender, make sure thats there and full of coolant. Mine used to overheat until i went to the el camino store and bought a factory radiator shrowd. I'm running the stock fan, and stock radiator setup, on a built motor with ac and it never hits 200, and i live in central california where 100 degrees is an average summer day. I'd check all the usual things, thermostat, hoses, overflow tank, etc.
I think i might even have an extra overflow tank for the camino somewhere in my garage, i'll take a look.
Dave
St. Jude Contributor
I'm gonna offer a dissenting opinion here. My big block always runs nice and cool, right up until mid-June, when it does exactly what you describe, though not quite as hot (I get up to 210 or so). I'm cool all the time, until I get it above 65MPH on the highway. My radiator's fine, my air "scoop" under the front is in place, my shroud and all the foam are there (though the shroud and foam are fairly irrelevant at those speeds). I think it's just a matter of relatively high RPM and REALLY hot pavement a few inches underneath your radiator making the difference. I've even noticed that when I hit a strip of highway with those big concrete barriers on either side where they're doing construction, the water temp goes up a degree or two (lot of highway construction down here--it's like riding a luge course in your car between here and San Antonio).
BTW, my understanding has always been that 210 is not really all that hot for a big block, though 220 might be starting to push the envelope a bit.
JB
JB
JB
JB
