Replacing Snubber Bushing...Need Some Advice
Vetters, I need to replace the pinion snubber bushing (Upper and Lower). Never done this before but I am more than capable of doing it. Looked through the Tech Tips no luck.
Can this be replace easily? Advice welcome.
Randy
Randy
Should be fairly straight forward. I think it's supposed to be torque to about 70ft-lbs. Just unbolt it, keep everything in order, then reassemble in the same order. The hard part is getting a wrench on the top of the bolt to hold it from spinning. It seems like it hits somewhere all the time. A wrench with an offset would be best.
Last month I gave it a 30 second look and said "No way!" took it to a Vette shop and they replaced upper/ lowers, universals and replaced all french locks/bolts for under $300. Well worth every penny.
Premium Supporting Vendor
Originally Posted by Randy 71
Besides the bolts for the snubber mounting bracket, did you have to loosen any other bolts on the diff?
Scroll to FC-09 & FC-09P
http://www.vansteel.com/index.cfm?fu...&SubGroup=1004
