quick power steering question
I'm dripping fluid out of my power steering ram, where the long shaft extends from the body of the ram. Is there any way to fix this, or should i just replace the piece, its an origional 1973 item.
The short answer is buy a new one, they are cheap and keep your original. The long answer is you can buy a rebuild kit and you can try rebuilding it yourself not worth the bother unless you have the proper tools.
