Cam machining older block
Have a 74 454 that I want to install a cam in. Have read in several places that new cams need to be machined (cam end) to fit "older" blocks. What is considered older?
Interesting!. I think if you install a hydraulic roller cam or solid roller cam the end may need machining or installing a cam from a cam from a newer chevy V-8, 1986+?
DM.
