Screen resolution to fit posts properly?
Ive got a 19 inch monitor now set on 1024 x 768 resolution.
Looking at the index I can see everything, but when I open posts, I cant and have to scroll over just to read them.
Is there a way to control this so it stays in my screen?
My Solution
See it at: http://www.apple.com/displays/specs.html
So--what is the problem here? The first " all topics " page is just fine--but when you select a single topic--WHAM instant large screen--SO is it our individual screens or is it a Forum thing. AND why isn't someone in charge telling us?
SEMPER FI--1970 Dave
Originally Posted by Z-man
Hmmm - I'm using 1024 X 768 and have no problem seeing everything. No scrolling...
There are some times when someone posts a picture that is 1600 X 1200 or something larger that will cause your browsers to enter scroll mode to allow you to see the whole picture. (We should encourage people to size their pictures down).
Another instance is when someone enters a long string of characters (like ZZZZZ or something) with no spaces in it. If it is wider than your screen, the browser will display a scroll to allow you to see the whole line.
CI 7-8 Veteran
Why can't this software retain the functionallity of the old one where it resizes the picture if it's larger than the "normal" size. And then you click on it to see full size. Has everyone already forgotten about that? Maybe it's a setting or something that Troy isn't using???
Troy, where are you?
Originally Posted by Shylor
I just tried increasing the dpi to 120. But some stuff is still small and others just doesn't look right. Guess I was just used to 800x600.
I changed the dpi to a custom setting of 115dpi. What are you guys using with a 17" monitor and the screen resolution at 1024x768?
