rear caliper
rear caliper
rear caliper seems to be sticking. what needs to happen? will i need to drain all fluid out before i disconect caliper.what causes them to stick.wouldn`t be to cool a hundred miles from home!
Location: Pottsville, PA. USA Home Of America's Oldest Brewery Yuengling
Received 2,239 Likes
You only have to disconnect the rear line at the caliper.
This is a fairly common problem. Usually the culprit is the brake hose, with age they will get soft inside and collapse, this will cause them to act as a check valve and not let the fluid to back off of the caliper causing it to stick.
Mike
Mike
