Antenea Relay Location 80 vette
My antenae is stuck in the up position. Where is the antenae relay located? Both fuses check good. My book says rear console?
it is in the rear compartment opposite of the battery compartment. There should be three relays there. They are mounted towards the front of the tray compartment. (you have to remove the plastic tray first) The relays are mounted forward under the actual tray. I don't remember now, but I think it is the one in the middle. Good luck!!
