How bad are the stock exhaust manifolds?
How much HP will I be leaving on the table if I just put true duals on my 79 (also remove the cat)? It has been recommended to me to only use ceramic coated headers, how much HP will I get for the $300-$400 for ceramic headers? I expect 20 to 30 HP with just the duals no cat, is this realistic?
Thanks
Thanks
Thanks
Thanks
I can't give any hp figures, but fitting true duals was the single best power gain I did. Really woke it up. If you're thinking of Headers then do it all at once. My Dynomax Headers were an easy fit (no aircon to worry about, if that makes any difference) but plumbing them into the dual pipes was the tricky part. I ended up making another exhaust system as it was easier than moding the existing one to fit the Headers!
