New Owner question re: Flushing the cooling system
My baby is in need of a cooling system flush. Tested the coolant and it was well within the proper range - but there is lots of "junk" floating around - I believe this is due to the car sitting quite a bit with the previous owner... My question: I am going to take her to a oil change shop that I have used for years on my generic cars. Is there any direction I should provide them and/or things I should be careful of?
Thanks for any guidance.
Steve
[Modified by Silver72, 12:33 AM 7/8/2004]
Steve
Re: New Owner question re: Flushing the cooling system (Silver72)
Iv'e had good luck with draining and using a pour in flush.... read and Do then use (me is 50/50) mix ... i do flush 3 times after adding
flush to system.
flush to system.
I've never tried the "type of pressurized flushing system" I've always did like Comp just said. Maybe the pressurized would be better, I don't know. Someone else might chime in.
