Where can I get 4" side tubes?
I just got a set of Hooker headers (from a forum member!) and now I need a set of 4" side tubes. I will be getting spiral baffles for this setup as well. Can I use 4" truck stacks?
I found the tubes at Jegs for $219.99-
anywhere cheaper? Note this is for the black- I want black with a chrome heat shield- this is a driver car and can't have the gf getting burt getting in and out.
Thanks!
~Kevin
Thanks!
~Kevin
Re: Where can I get 4" side tubes? (Evil_1979)
Summit racing sells the replacement tubes also. Not sure how much the black ones are but the chrome ones are around $255.00 a pair
We have a guy that builds truck exhuast just around the corner from me and he stocks everything right up to 6 inch. Even 6 inch mandrel bent 90's. 4 inch is considered small for any truck place but they can provide you with the 4 inch pipe and a tight 90 to weld on the turnout. YOu can have them cut a 90 in half and make 2 turnouts from the one 90.
It will be alot cheaper.
