help with front coil's
I'd like to drop the front end down some and I'm thinking of cutting the coils. How much do i cut . I drop the back with a kit from ecklers now I want to bring the front down. Should I start with the 1/2 coil first?
I really need ya'lls help. Thanks Vince
Re: help with front coil's (vincevette78)
you have to line up the ends when you cut them!! so a half of coil really wont work but a full coil on stock springs will drop you about a 1 1/4 roughly i cut 1 coil off my front springs it worked out nicely
CI 6-7-8 Veteran
CI-VIII Burnout Champ
St. Jude Donor '06-'10, '13
Re: help with front coil's (killervette666)
Start with 3/4 coil, install (correctly) and drive for a while to let them settle. Then go from there.
You can always cut more, but you can't put back what you have cut off.
