Differenent gear ratio with upgraded engine?
Hey everyone,
I'm trying to work out my shopping list for a replacement engine for my 73 L48. I'm leaning towards a 383 with Vortec heads, Comp Cam, and good air flow components. I suspect that this will put out about 350 HP with 425 ft-lbs torque. However, I'm concerned that the higher engine power will warrant a lower gear ratio... I'm running a 3.36:1 now, and if anything I feel like it zips through the gears too quickly, even with my little 190 HP L48.
This is for street use, and I'd like to strike a reasonable balance between fuel consumption and acceleration. I'm on a budget, but should I change the ratio? How is the best way to accomplish this? New ring & pinion set?
Thanks all!
Dave
Thanks all!
Dave
Location: The reason time exists is so everything doesn't happen at once
Re: Differenent gear ratio with upgraded engine? (humiliategravity)
I think a 3.36:1 waas pretty much the standared rear with the big blocks of the mid to late 60's. When you say a lower ratio, I assume you mean lower numerically like a 2.53:1, not something like a 4.11.
You're best bet is to leave the rear alone for now (since your on a budget anyway) and see how it is with the new engine. You can always change rears later.
The resulting feeling that "my little L-48 zips thru the gears too quickly" could be because the wimpy camshaft runs outta steam by 5000 RPM (?);
with a stout cam & "good air flow components", 6000 RPM isn't out of the question.
5000 RPM, with a stick & 27" tall tires (255/60R15) in Fourth Gear 'should-be' approx 120+ MPH;
60 MPH should-be approx 2500 RPM.
You may wanna leave the gear-ratio alone and 'see' how it runs; you can always change it afterwards...
[Modified by Glensgages, 4:38 PM 7/6/2004]
Re: Differenent gear ratio with upgraded engine? (Glensgages)
I went from a 3.70 to a 3.36 and LOVE it. I think it's a good compromise for street driving with monthly visits to the track.
Re: Differenent gear ratio with upgraded engine? (isosceles)
Thanks for the input guys. Isosceles - what kind of HP/torque are you running with the 3.36?
Dave
Dave
