No brakes lights!
No brakes lights!
I have driving lights and turning signals, but no brake lights. Any thoughts on where to look for the problem? I hate eletrical problems! THANKS
Re: No brakes lights! (Scudd)
Check the brake light switch that gets actuated by the brake pedal, The turn signals and the brake lights are on the same circuit so if the signals work the problem is probably the brake light switch is probably bad or needs adjustment. Hope this helps
Re: No brakes lights! (tom102)
Do not go The answer is above.
