Wheels on C3's if you know wheels then please answer
Old 07-06-2004, 01:32 AM
wgc_3
wgc_3's Avatar
Default Wheels on C3's if you know wheels then please answer
What do I need to do to be able to put C5 (Z06) wheels on my 76?
Old 07-06-2004, 01:44 AM
Metal Wulf
Metal Wulf's Avatar
Default Re: Wheels on C3's if you know wheels then please answer (wgc_3)
http://forums.corvetteforum.com/zerosearch
Old 07-06-2004, 08:55 AM
zwede
zwede's Avatar
You need wheel adapters. Call vettebrakes and they should be able to tell you what part numbers you need. Be prepared that they are expensive.
Old 07-06-2004, 12:08 PM
wgc_3
wgc_3's Avatar
Default Re: Wheels on C3's if you know wheels then please answer (zwede)
Thank you I have contacted them.
This is what i needed.
Thanks,
wgc
Old 07-06-2004, 12:11 PM
BSeery
BSeery's Avatar
CI 6-7-8 Veteran
CI-VIII Burnout Champ
St. Jude Donor '06-'10, '13
yes, with adapters from Vette Brakes, and you will love the improvement in handling.
Old 07-06-2004, 01:16 PM
Schmucker
Schmucker's Avatar
Doesn't Corvette Central sell Z06 wheels that are a direct bolt on?
Old 07-06-2004, 01:51 PM
killervette666
killervette666's Avatar
Default Re: Wheels on C3's if you know wheels then please answer (Schmucker)
I doing the same thing except slightly more diffrent, i recently got 3 piece 17 by 11 rims that have 8 inches back spacing, im hoping with vbps 3 inch adapters theyll fit since we already cut off the emergency brake bracket. If not you can always find a local machine shop that will be able to fab something up for you, we found one but itll be just a bit more expensive. Hope this helps you out.
Old 07-06-2004, 02:12 PM
CrossedFlags77
CrossedFlags77's Avatar
Old 07-06-2004, 02:30 PM
wgc_3
wgc_3's Avatar
Default Re: Wheels on C3's if you know wheels then please answer (CrossedFlags77)
Killervette! Thank you so much. You just saved me about 300.00!!!
Thanks man!
Anything else I should know before I put these on my 76?
Old 07-06-2004, 02:45 PM
killervette666
No problem, always glad to help out a forum member
Just make sure to measure everything out so that you know they will fit right, itd be a shame if you get the adapters and they turn out to be too small.
[Modified by killervette666, 2:31 PM 7/6/2004]
Old 07-06-2004, 03:32 PM
MEGALADON
MEGALADON's Avatar
Location: WAY DEEP INSIDE AMERICO,YES YOU LIVE HERE TO!! TX
Default Re: Wheels on C3's if you know wheels then please answer (killervette666)
I have a set of Z06 (GM) chrome wheels, CHEAP, with tires
4/sale they fit with 2-3/4 adapters
Old 07-06-2004, 06:01 PM
wgc_3
wgc_3's Avatar
Default Re: Wheels on C3's if you know wheels then please answer (MEGLADON)
Nah, but if Corvette Central has them then I won't put money into adapters, thank you though.
Sincerely,
wgc
Old 07-06-2004, 06:45 PM
wgc_3
wgc_3's Avatar
Once I buy these wheels from Corvette Central, will I have ANY complications that anyone knows of?
Thanks,
wgc
Old 07-06-2004, 06:54 PM
Oldguard 7
Oldguard 7's Avatar
tomz wheels has chrome ZO6 wheels for $849 a set.
Old 07-08-2004, 12:26 AM
wgc_3
wgc_3's Avatar
Default Re: Wheels on C3's if you know wheels then please answer (Oldguard 7)
Ok what the heck I just logged on to Corvette Central to buy the Z06 wheels and they're gone!!!
This really isn't good!
Please someone tell me it's just me?!
Thanks,
wgc
Old 07-08-2004, 12:34 AM
CrossedFlags77
Here is a link to the page they are on.
http://www.parts123.com/PartFrame.as...rvette_Central
And if that doesnt work the part numbers are.
For the chrome - 643042
For the black - 643069
Hope that helps.
Old 07-08-2004, 12:38 AM
wgc_3
wgc_3's Avatar
O i love you thank you!!!! For some reason it doesn't show up on my pc!!!
THANK YOU!!!!
To Wheels on C3's if you know wheels then please answer
Quick Reply: Wheels on C3's if you know wheels then please answer
