Ash Tray / Lighter Conversion (to hidden switch panel)
"Rodstoration &am p;quot; In Progres
I've decided to make my C3 more personalized vs going stock. Given I'm a nut for gagets and messing around with electrical, I've decided to convert the area below my ash tray / lighter door into a concealed sitch panel (i.e. fan override, electric fuel pump, etc.).
As anyone done this and could you post some pictures. I'm currently searching for a panel that will simply mount in once I cut out the base of the lighter and ash tray.
Thanks
Thanks
Re: Ash Tray / Lighter Conversion (80TexasC3)
Just a silly idea but if they make reproduction ash trays why not just take out the lighter and put the switches in the ash tray that is there.
Re: Ash Tray / Lighter Conversion (SHAKERATTLEROLL)
I'll take some pictures tomorrow and show you what I did so far... Basically, used a dremel cuting wheel and sliced the base of the ash tray and lighter off. Created a lot of room to work with wires while leaving the top shelf for mounting the switch panel. Now the key is to find a panel that works (size).
you are correct... I do want to keep the cover functional and cover the switches up.
My panel is relatively small due to only having a switch for my electric fan at the moment. If I ever need more room I will cut out the lighter and make a bigger panel. I just used some aluminum from Home Depot and cut a size to fit. A little gluage (is that a word) at each corner and it stays in place, and if I ever want to do away with it, it will be an easy pop out. Sorry for no pics but I will have some tomorrow after I charge my digital camera battery.
Re: Ash Tray / Lighter Conversion (CrossedFlags77)
Thanks... and I like the idea of making my own... creates more of a sense of accomplishment that way.
