Brake master cylinder question
Does the front brake fluid res on the master cylinder service the front or rear brakes on a 73? I need to bleed the front res and I want to make sure I do the right ones.
Thanks!
Thanks!
Re: Brake master cylinder question (blunsford)
IF the lines are hooked up right, the front is the front, and rear the back brakes. You should be able to trace out the hydraulic circuit to the brake block rather easily to confirm this.
I believe solid lt1 is right, but when bleeding you should really bleed all 4 wheels with the rear wheels lower than the front and start at the right rear, then left rear, right front and left front
Re: Brake master cylinder question (crazcorkath)
