Flywheel bolts, correct size???
I'm about to bolt the flywheel to my new 383, and I realized I don't know what the correct size for the crank to flywheel bolts is. I seem to have misplaced my originals from my L-48 so I have nothing to reference. Anyone know the answer Also, when I buy the new bolts what should I use for a strength level? Grade 8? Hardended bolts? I'll also be sure to use thread locker when installing also. Any help would be great
Senior Member since 1492
Re: Flywheel bolts, correct size??? (Ryan77)
These bolts would be grade 8.
Re: Flywheel bolts, correct size??? (mapman)
Use the ARP or mid 80's Chevy flywheel bolts, you can get them cheaper from Pioneer at a local automotive machine shop (the Chevy bolts are quite good but, ARPs are the best.)
