power valve location
Old 06-30-2004, 11:37 PM
79 Bullet
79 Bullet's Avatar
Default power valve location
I have a Holley 650 Double pumper 4150 series where is the power valve front or rear bowl or do I have two?
Old 07-01-2004, 12:44 AM
After Shark
After Shark's Avatar
Default Re: power valve location (79 Bullet)
both front and rear
Old 07-01-2004, 01:30 AM
79 Bullet
79 Bullet's Avatar
Default Re: power valve location (After Shark)
when i replaced me spark plugs the front four where fouled. Is it safe to assume that the front power valve is gone? Is there an easy way to check with taking the carb apart?
Old 07-01-2004, 06:57 AM
Gordonm
Gordonm's Avatar
My 750 DP only has one in the front. A quick way to check is when the car is idling put your finger over the vent tube on the carb. If the motor floods out within seconds it is bad. If it continues to run the PV is OK.
Old 07-01-2004, 10:07 PM
Vetterodder
Vetterodder's Avatar
Default Re: power valve location (Gordonm)
My 750 DP only has one in the front. .
Are you sure that it's a double pumper (accellerator pumps on both primaries and secondaries)? DP's come from the factory with pv's (and jets) on both ends but racers sometimes eliminate the secondary pv and compensate with larger jets.
To power valve location
Quick Reply: power valve location
